I am looking into buying an electrical circuit tester. Does anyone have any info on which one to buy. I am the type of person who does not mind paying more for quality. Not saying I want the most expensive, but some brands are better than others.
The fluke may be overkill unless you are going beyond the minimum SOP.
Suretest is something you can use non-invasively and it will give you a lot of information. With a ground pigtail adapter you can check bonding on a lot more than receptacles.
