Clay tile eave closure
Thank you Barry. post edited.
You mentioned “Accessory closures may have weep holes to allow water drainage and eliminate damming at eaves”, and this is my main reason for the post. From a roofing perspective, will this water be running on the sheathing (the area under the hump portion that is covered by the closure) and might pose water damage to it?
