Hi, this is a first for me - a client reached out 3 months after the inspection stating that the ducting in the crawlspace was damaged by rodents and some ducting connectors were separated. He asked if I had errors and omissions insurance (I do have it). He says he got an estimate of $7000 to repair/replace the ducting and wants to be compensated for the cost.
When inspecting the crawlspace there were no visual damages of the ducting in the crawlspace and no signs of rodents. However, I reported mouse droppings in 2 areas inside the house. Also, there was s lot of moisture in the crawlspace and floor insulation was hanging loose and had fallen to the ground.
He had an HVAC team go into the crawlspace and they took pictures of the damages, which he sent me The pictures I took were unfortunately only a few and did not show any damages (I usually take pictures of things that are faulty etc and so in this case, don’t have pics of the entire crawlspace, specifically the areas the sent pictures were supposedly from). Lesson learned to take pictures of everything!
Is it possible that in 3 months time, the rodent population could have grown, found ways into the crawlspace and damaged the ducting?
Is it possible that the moisture in the crawlspace could have loosened the tape that kept the ducting pieces together and by turning on the heat, by the force of the air, the ducting could have then separated within a 3 month time span?
Any advice on how to handle this situation? Any legal advice?
Any advice is highly appreciated!
Thank you,.
Harald
