I really am not knocking him but I really don’t have time to read a long description about that. There may be some valid points but the should be short and sweet. I have a business to run here. Just because you write a 40 page response doesn’t make it the best, especially if you ignore the wording on the form. That’s why I said you could read the “expert” because I don’t have that kind of time.
I can add just fine, Robert. You are incorrect about placing the connectors on the outside of the wall. Who does that? This is very rarely done unless it is retrofitted after interior finishes are installed, or for some other access issue. 99% of framed wall roof tie-downs (basic clips) are installed after the sheathing is on, from the inside. The reason this clip is on the joist is because the installer doesn’t know how to flip it around and install it on the rafter side…must be left handed. You should know this if you actually did frame a house.
Jerry Peck says that rafter is not even toe-nailed. How in the hell does he know that, and is most likely incorrect. Think about it.
Seriously though, what is he talking about? I have built houses and buildings in NJ and FL. Just because you say its so doesn’t mean it is. Cant see the forest through the trees…
What good would giving him the answer do if he didn’t understand WHY it was the answer?
That’s the point of the response….to “teach” inspectors to make these decisions based off verifiable and accurate information that supports their conclusions. Not speculation or voo-doo science nobody can understand (why do you think he doesn’t know in the first place?).
I answered his question in the same way I was taught….”here are the facts, you tell me”.
Contrary to popular belief, simply giving inspectors the answer teaches them nothing.
It may help pass a test, but the end result lacks substance.
