Illustrative photo, thanks!
Where is this information from? I’ve worked on tons of old homes and office buildings that had tinned copper conductors be it AC cable or NM and the “cloth” was always on the outside of the rubber insulation.
Link in his post…
Sorry I was asking about the information in that article which seems to be incorrect.
Never seen this before, but interesting.
Asbestos wiring insulation | ELG Law
Looks like he copied from this guy or vice versa. LOL
Don’t know where he got it from.
What is Cotton Cloth Wiring? | Glenco
Hi Jeffrey, what is the difference? They are so often used interchangeably.
I’m taking a guess that “tap” has something to do with where the power originates (tapping the power) and lugging refers to any wires that are doubled?
Thanks
Ok so here is the final answer to this question. I have done so many inspections in the Tampa Bay Area in the past year and came across this type of wiring question very often.
4 Point is important in Florida because that’s the inspection form your insurance of choice looks at. I have seen wiring dating back to the late 1800’s and today. I am not an electrician and I have unlimited respect to ones that break it down to a science backed up with experience and I know a few. I agree that the Citizens 4 Point form is a mess but hey what government form isn’t ? It always has to have 2 to 100 different meanings and that’s why it’s government. When you can’t figure things out you just protect yourself by playing with words…riiiiiigh?
After numerous consultations with experienced electricians, insurance agents, underwriters the answer is the wire itself is covered in pvc rubber, and is actually “cloth jacketed wire”. In the truest sense of the word it is technically cloth covered, but the hazard of the older wiring is that the older rubber became brittle, whereas this wiring has more covering around it, which, to date, GENERALLY has not shown the degradation issues as with its predecessor.
So the answer is NO it is not cloth wiring that the form asks for. Now, here is the flip side. If this same wiring is not grounded in the panel and at the receptacle, switch or light or if it is damaged by rodents, deterioration, unstable voltage well then it’s an issue. A licensed electrician with a good standing reputation in business, will be able to determine this really easily. My good friend who is an insurance agent in Florida has shared a screenshot of the Citizens explanation of “Cloth” wiring that I attached here for everybody to see. Why should it be a secret, to make more money for the insurance companies and let them monopolize a market? If you need us to check for something you want to write the rules for then have your underwrites educate the ones checking for it. That’s why I say ASK, LEARN, SHARE it’s the only way.
To conclude, being a certified, state licensed home inspector is not just passing the tests and getting a license guarded by an insurance policy. It is about experience, not being afraid to ask around, building your network and most importantly SHARING YOUR KNOWLEDGE with others. Not everybody can pass for this career and the ones that are not willing to learn, ask and share will just end up with unsatisfied customers and lawsuits.
Citizens Definition:
The lighter colored cables look like early NM cable, certainly not knob and tube. The insulation is thermoplastic, not rubber or cloth. The overall dimensions are larger due to a difference in insulation type. Older cables used TW insulation vs todays THHN. The earliest cables did not contain a ground. Later versions had an undersized ground.
Knob and tube had individual conductors with cloth insulation.
PVC is not the same as rubber.
Type AC cable had rubber insulation over tinned copper conductors.
