Did a 1940s house yesterday. Attic span was approx. 25’. Rafters were 2x6. No collar ties provided, yet no evidence of sagging. My interior attic pics didn’t develop well. Exterior pic is below.
Question is: when would you say collar ties are necessary? Who would you refer the issue to: roofer or general contractor?
the requirement for collar ties is an engineering call, I would normally only query the lack of them if I could see rafter or ridge sagging. In most homes the ceiling joists run in the same direction as the rafters, so unless the rafter is very long they are not needed.
Joe
If it ain’t broke, don’t fix it. You can’t retro legislate. If the code didn’t require collar ties when the house was built why put them in now. I don’t think you have to worry about snow loads where you are and if the attic is in good shape and there is no rafter sag or walls bowing why bother?
Larry
