Would love some direction on the possibility of me inspecting a community water well. I was contacted to provide regular inspections of a 12 home community water well. I have come up with the following areas for my inspection. Does anyone have experience with this?
- Water quality testing
Test for bacteria/coliform, E. coli, nitrates, hardness, iron, manganese, TDS, pH, and any local concerns. I already do this so not a concern. - Capacity
Confirm the well can support peak demand for all 12 homes, not just one house. Peak demand is summer weekends. Regular use is 2-3 homes. - Pressure and storage
Pressure tanks, booster pumps, storage tanks, cycling issues, leaks, and pressure drops when multiple fixtures run. - Treatment equipment
Identify filters, softeners, chlorination, UV, reverse osmosis, or other systems. Note condition and maintenance. - Well head and protection
Check for proper cover/cap, electrical safety, grading/drainage away from the well, flood risk, and distance from septic systems. - Shared responsibility
12 Home HOA is responsible for the upkeep of the well. - Power
Electrical inspection of connected components.
Thoughts? Areas I might have missed? Thanks
