This is dumping into a foundation drainage system. I am writing this up that it needs to be discharged elsewhere. There is a main sewer line directly above this can it be dumped into there or should it be ran outside? Thanks for any help with this
If discharged into the drainage system equipment shall drain by means of an indirect waste pipe.
https://inspectapedia.com/aircond/Condensate_Drains.php#Code
