Condensate Drains and Air Gaps - Why?
I’m having a little trouble understanding this concept from the text:
6.3.3 Condensate Drain Connections
Condensate drains from air conditioner coils, condensing furnaces, and heat-recovery ventilators should not drain directly into a DWV pipe. An indirect drain using an air gap should be installed. In some locations, the direct connection of a condensate drain line into a stack is not permitted, even with a trap. The potential danger is that sewer gases may enter the house through the condensate drain line. It is not a cross-connection problem, but it is unsafe and unhealthy.
If the “potential danger is that sewer gases may enter the house through the condensate drain line”, wouldn’t that also happen through the air gap? I understand the function of the trap is to stop the sewer gases from entering the building, but I don’t understand why directly connecting condensate lines is prohibited.
Is the rule in place to stop shoddy installs?
Is it because the connection to the DWV wouldn’t be trapped? But then there is this line:
No because the condensate drain is up stream of the P-trap it’s draining into. The sewer gas will be stopped on the other side of the trap.
There would be nothing to stop the sewer gas from entering the condensate line if it’s connected directly to the DWV system.
The Charge of the Light Brigade
“Theirs not to reason why,
Theirs but to do and die.” :rofl: :joy:
Thanks Martin,
Your explanation makes sense! This was one of those times where I understood the parts and pieces of the system, but just couldn’t visualize their installation arrangement.
condensate_air_gap
Any thoughts on why a direction connection with a trap would be prohibited?
With a direct connection, even with a P-trap, sewage would be allowed to enter the inside of the air handler.
unnamed
That makes sense.
Some air handlers cause a negative air pressure in the condensate drain line.
Also any trap in a direct or indirect drain will dry out when condensate is not produced because the a/c does not run in the winter. That is why some areas do not allow any connection to the sewer vent.
There is a “Wet Trap” device that can be installed to keep a trap full. But installing one is costly, will freeze at an unconditioned location, and negates the reason your dumping in the sewer in the first place. “Cheap and Lazy”.
David, your post makes a lot of sense! Thanks for the help!
Also it keeps bacteria from multiplying up the condensate drain
I don’t think I’ve ever seen it done like it is in that picture. Do condensate clean out risers effectively create this air gap?
Those risers are incorrect.
Done all the time, still doesn’t make it right.
The air handler either sucks or blows down the pipe. Either way, it’s wrong. This one blows because it is a gas furnace. The quantity of air blown out the drain must be made up by sucking unconditioned air into the house from elsewhere, like a water heater flue etc…
Thanks, very interesting. How should they be? Would caps on them fix that condition?
Good diagram. The air gap shown will perform the same function as a drain vent After liquid goes through the air gap will prevent the column of water on the downside of the ptrap from siphoning the water out of the p trap.
See pic from an inspection I did today. I understand why there is an air gap and p-trap, but is it ok to have such an open connection where the condensate lines meet the drain?
I would think there needs to be an air gap between the termination point of the condensation line and the drain.
This from AI.
  1. Purpose of Condensate Drain Lines:
  • These lines collect water (condensate) produced during air conditioning or heating operation.
  • The condensate typically drains into a floor drain or a designated outlet.
  1. Air Gap and Ventilation:
  1. Why Not Direct Connection?:
  • Directly connecting condensate lines to a DWV (drain-waste-vent) pipe is prohibited in some locations.
  • The potential danger is that sewer gases may enter the house through the condensate drain line.
  • Even with a trap, direct connections can allow sewer gas to enter the air handler, which is unsafe and unhealthy.
Screenshot 2024-03-20 at 4.41.05 PM
This is correct :point_up:t2:
OK thanks guys for the clarification
