I have some possible homes for my Mock inspections but the main question I have been getting is “Can I get a copy of the report?” Is this possible using the reporting software through the SOP Reports?
Your mock inspections are usually generic and submitted to the “system “. More likely to be never looked at or seen again. Don’t worry about them too, if at all.
So, to clarify, I would not be able to get a copy of the report to give to the homeowner, is that correct?
@aprehn If you are using any software at all (Several free trials out there), then you will actually have all of the info for the report that you make. If you understand and know how to tweak the software, the client that owns the house can be copied when uploaded.
Tt all really comes down to the program you are using to make the report, which in my eyes, is the final document that people will reference and remember you. Do your own house first and start to get familiar with the program you opt to go with and use.
If you are not ready to make a report on your own house, and view it as a customer. I would recommend to really work on the presentation factor before you get into someone else’s house.
First, to submit a mock inspection to InterNACHI, you must use the checklist (link below).
Why would the homeowner rely on mock/training material? I would be very clear with the homeowner about this. And very clear within any document I present to them. i.e. THIS IS TRAINING MATERIAL AND NOT TO BE RELIED UPON. THIS IS NOT A HOME INSPECTION.
Thank you all for your responses, they have answered the question and are all very helpful.
Yes you can view all your sop reports you submit. The sop report system produces very basic reports. You should not use these for real reports. As there is missing vital information on them.
