Copper to PVC
Originally Posted By: kfrancis
Inspected a house with original copper throughout the house. In various areas it has been replaced with PVC. Not sure how to recommend on the plumbing.
Originally Posted By: dedwards
PVC or CPVC? Makes a difference. Photos would help if you have some.
Originally Posted By: cfuoco
Supply or waste?
Originally Posted By: jpope
That's key. PVC is not allowed for use in distribution. CPVC is.
Copper to CPVC (or CPVC to copper) is common and okay.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: cradan
Transitions and connections need to be observed carefully. If you are looking at threaded connections at any point in your system, be aware of male copper (or other metal threads) x female CPVC connections. Folks tend to over-torque the metal threads into the CPVC female receptor…CRACK!!! Done it myself a few times. Check that…more than a few times.
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
