Hi to all,
I had Hank send me a better picture of this system, as it is somewhat unusual even in these parts, and unheard of in the warmer climates.
This is a single line steam system
The components that hank was originally asking about are the Low water shut of and auto fill (the black rusty thing) and the top control is the pressure limit switch.
Originally Posted By: jsavino This post was automatically imported from our archived forum.
The owners of that heating boiler never maintained the low water cut off.
They never blow down the low water c/o and the dirt pocket.
I would recommend replacement because the float assembly inside may not work as intended and may not shut the boiler down on low water.
And recommend that the pressure control on top of the low water cut off be mounted directly to the boiler, not in the control. The boiler will operate less and still provide steam to heat the home.
Gerry, there is no auto feeded on that low water control.
-- John Savino
HomeWorks Inspection Services, LLC
St. James, NY
631.379.4241
Sorry John you are correct I had a "mind fart" between Hanks picture and my diagram thanks
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
You aren't kidding, Gerry. I would have written that it had a corroded gitzenblizzen, and the corrosion would cause the thingamabobber to leak if not corrected!
