Cracked Paint under window
Can you tell me what is causing this cracked paint on sheetrock.
Older house on a crawl space, wood double hung window above with full storm window on it. Facing West. Wood lap siding. No visible penetrations on the exterior or interior of the window. Individual window stiles showed water staining from condensation on the panes.
http://www.nachi.org/bbsystem/usrimages/crackedwallpaint.jpg
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: dgreen1
Erby,
Could it be either moisture coming in around the window frame or it could be past moisture damage from leaving the winow up. It appears that there may some staining on wall right under the window frame. The second is my best guess.
Michael Green
1-877-INSPECT/InspectorUSA
Kaesar & Blair Advertising Specialties Dealer
Originally Posted By: rhinck
Erby,
Here is another possible scenario. I have found this around and below a window that had the curtain pulled shut almost on a permanent basis. My guess is that there is excess moisture buildup behind the curtain due to the condensation on the cold window that never gets "wiped" with air movement. That's my guess-hope it helps!
Rick
Heads Up Home Inspections, Inc.
Originally Posted By: jonofrey
Moisture barrier on wrong side of wall.
Inspection Nirvana!
We're NACHI. Get over it.
Originally Posted By: nlewis
Erby,
1. That window sill looks beat up from sliding a window AC in and out. Could it be from condensate not draining outside?
2. Were there weep holes in storm windows that were clogged up?
Originally Posted By: Greg Owens
I think Rick is on the right track it looks like those are heavy thermal curtains going all the way to the floor probably there is an air register behind that curtain when it is closed also.
Originally Posted By: jfarsetta
Looks like moisture, or perhaps even mold, behind the paint. Have seen this in moist, finished basements before.
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Originally Posted By: dvalley
Erby,
This is a training session, huh? You know the answer but need to teach us new Inspectors what to look for.
My guess....No Insulation in the wall cavity. Causing moisture build-up on the exterior of the drywall. This is due to humid home heating and cold air meeting on the exterior of the drywall. Paint will not adhere to moist surfaces. Or like John O. had stated...the moisture barrier is facing the exterior of the house. The moisture barrier should always face the warm side of a house.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: ismetaniuk
This membership was a big waste of my time!
Igor
Top To Bottom Inspections
Glen Spey, NY
We may never know.
I recently talked with both the sellers and the buyers about a different issue.
Seller had offered to open up the wall to see what was there. Buyer declined.
Tomorrow's another day.
Erby Crofutt
www.b4uclose.com
Erby,
Were these single or thermal panes?
David Valley
http://www.nachi.org/newenglandchapter.htm
email us at: [email protected]
David Valley
MAB Member
