NO installation of any interior basement drainage system STOPS further deterioration n further water penetration, NEVER happen
see the bottom blocks?
:20 mark… what, install a dumb azz interior system? shtttttt
he says, damage almost always occurs BELOW floor… i’ve seen many deteriorated, disintegrated blocks just ‘above’ the floor, just sayin man
Duh, can some see WHY the Int system crooks want to cover, hide, conceal part or all of these basement walls? HELL------------------------------------ooooooooooooooooooooooo
They don’t want the homeowners, potential homebuyers, home inspectors etc to SEE water, mold, efflorescence, wall bowing in, crack widening, deteriorated blocks
Here in St Clair Shores, young chick just bought this joint…1st house
she had 7 other companies over… all wanted to install an interior drainage system = incompetent, crooks etc
the SELLER’S patched + painted over cracks in walls + deteriorated blocks, sure did
she says higher bids $15K ish for a wiener filled INT system… this was 7 ish years ago, MORE $ now eh
we did the job, EXT waterproofing $4K back then… and yes MORE now lol
There were multiple exterior cracks in the block walls, bottom course deteriorated and some other direct openings into basement (around windows) so THOSE were WHERE the stinking water was getting in , had NUTTIN, zip to do with a need for better drainage or drain tiles pftttt
So as home inspectors, ummm don’t CHA’s think you could HELP your clients more if you see-know some of this shtt? I see a few HI’s call these INT systems out, warn potential buyers but not many, just sayin – some might begin to cry now lol (Yeah i get it, some home inspectors are IN-BED with some INT system companies === kickbacks $, scam, fraud)
