Is it OK for CSST to pass through a wall? I would think a sleeve is required? What are the applicable code sections? Thanks.
CSST can pass through a sheetrock wall without a sleeve as long as the plastic coating is intact and there are no connections within the wall cavity. If it goes through masonry or brick walls, it must have a sleeve. This is from Gastite tech support.
Crappy drip/dirt leg as well.
Nothing “crappy” about it. Just plain wrong ![]()
I think code doesn’t allow a flexible gas pipe passing a wall/floor
Thanks for your responses.
Nothing wrong with csst passing through a wall as long as it is sealed to the wall according to the manufacture of such a product.
(see page 34)
http://www.tracpipe.com/Customer-Content/WWW/CMS/files/152565_OmegaFlex_DIGuide_9.11.pdf
SECTION 4.4B —THROUGH WALL
PENETRATIONS
This applies to appliance connectors, not gas piping.
