I inspected a home today with a Triangle Tube boiler and I cant seem to located the data to figure out the age. The unit model # is PG-30NH and the Serial # is HM 1829. Can someone tell me the manufacture date on this unit. Thanks Chris Hill
Can you post a picture of the data plate?
I guess not! :roll:
Usually, the date is in the serial number.
A guess would be 1976 but the letters sometimes come into play, too.
There is a website that some older members put together for aging appliances, but I cannot remember the name of it. Someone will be along to help with the name, soon.
Try this: https://www.building-center.org
Or, call the manufacturer…maybe.
Newer than 1986. You may have to contact them to find out.
This unit. https://www.ecomfort.com/Triangle-Tube-SMART-30/p23178.html
Old thread from 2018.
Morning, Chris. Hope this post finds you well.
From the label the MN: is SMART 3:0
Is this a water heater tank support to a boiler or is the the water heater?
Howdy, I know this is an older thread but I ran into one of these same Indirect fired water heaters today that was connected to a hydronic boiler system. (The combined system provided baseboard heat and hot water to the home btw.) I called 856-228-8881 ext 575 and read the Serial # to the rep and got the age immediately and the supplier info as well.
Thanks, John.
