Deck specks
Originally Posted By: rsmith5
At an inspection yesterday and the deck ledger board was nailed in place, with 2x8 joists in 2x4 joist hangers nailed on with roofing nails. I wrote up that the hangers were wrong and that half inch bolts 2’ on center should be installed in the ledger board. The joists were ten feet long.
Was this correct?
Ralph
Originally Posted By: gbeaumont
Hi Ralph,
sounds good to me, I would have written up the improper hanger connections and also the lack of lag bolts (1 per bay minimum) also I hope to checked for ledger flashing and proper footings for the supports.
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: rmoore
While we’re on decks and proper footings I thought I’d share this from yesterday.
[ Image: http://www.nachi.org/bbsystem/usrimages/0/050421C014s.jpg ]
It's around a 20 by 20 deck with 2x6 joists, rim joists, and the central "beam". Three 4x4 posts supporting that "beam", no connections, all leaning and about to slip off the blocks. I wrote the whole thing up as inadequate construction methods, a safety hazard, and recommended they completely rebuild it. I just don't understand why someone would spend the money on materials but not the $10 on a simple "how to" book.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Thanks Gerry,
What was really interesting was the header at the front was constructed of 4- 2x12 PT with 1/2" PT plywood, set on 4x4 posts with two 2x4s attached to make them the full width of the header and set at 8’ on center. Oh yeah, they were footed on the concrete patio beneath.
Thanks again for the quick response.
Ralph
Originally Posted By: ccoombs
You can use smaller hangers than the joist. It would depend on the allowable load for the hanger. However, there is no way the roof nails are structurally acceptable.
Curtis
Originally Posted By: Michael D Thomas
Disclaimer: I’m not a structural engineer, and I don’t even play one on ther internet.
That said:
My understanidng is that when installing ?per manufacture? you have some choice in hangers, but you can?t use any size you wish; for example you can?t use a 2x4? hanger with at 2x12?, and that the minimum size for a given application is specified in a table provided by each manufacturer.
For example here's the table for Simpson hangers in spruce-pine-fir:
http://www.strongtie.com/products/connectors/hangertables/face_ss-spf1.html
The manufacture?s nail options ate listed at the bottom of the table.
Additionally, with the change over from CCA-C treated wood the hangers and nails acceptable for use with treated lumber have changed:
http://www.strongtie.com/productuse/corrosion.html
?While galvanized steel provides some protection, testing has shown that it is still likely to corrode if in contact with treated wood. The service life of galvanized parts depends on many variables including the location, installation, exposure, and the thickness of the galvanized coating.?
To make this clearer, here?s set of salt spray test photos for various fasteners:
http://www.911-nails.com/pt2000_product.php
Scroll down to the pictures, the results most for most fasteners (include most galvanized fasteners) are pretty discouraging.
Here?s the page for Simpson products for treated lumber:
http://www.strongtie.com/products/categories/zmax.html
IMO, current best practice for hangers and fasteners with new treated lumber in wet locations is SS.
