I don’t run across many of these situations around here. The vent pipe is about 7 feet off the sidewalk. Then neighboring home is over 20 feet away. The home is clad in vinyl siding. There is no manual available and was curious if there is a problem with this. To me, it’s a DLR (Doesn’t look right). Who would be the licensee for refrerral A Chimney Sweep??
Below copied from page 19 of the installation manual:
[size=3]B. The clearance to a window or door that may be opened must be a minimum of 48" to the side and 48" below the window/door, and 12" above the window/door. [/size]**[FONT=Arial,Arial][size=1][FONT=Arial,Arial][size=1]1
[/size][/FONT][/size][/FONT][FONT=Arial,Arial][size=3][FONT=Arial,Arial][size=3]With outside air installed, the clearances are 18" to the side and below and 9" above.
**[/size][/FONT][/size][/FONT]
Thanks,
I mentioned in the report that they should refer to the manufacturer’s reccomendations but there was no manual present. I forwarded the link to the manual to our client. So now they have the reference. I had a brain fahrt not to look that up. There were many other discussions that had me a little distracted.
The clients are from Florida and did not have any experince with Furnaces, Humidifiers, Attics, Basements and this home had all AND the home was built in 1885 with K&T and 2-prong receptacles, sagging floors…
