Disassemble water heater
In the course it shows a couple of different occasions where we should disassemble parts of the water heater. Is this correct because it seems like that would exceed the standard operating procedures?
IDK what you’re referencing in the video but inspecting a water heater is visual only. I would never disassemble anything on a water heater.
Like @dfreund said, water heater inspections are visual only.
It may be referring to removing access panels intended to be removed for inspection purposes. For instance, removing the metal cover over viewing port on the bottom of gas fired water heater to look at the flame color.
We are allowed to exceed the SOP. Determining when and where this is appropriate is up to the inspector. I do remove some panel covers when it is safe and will benefit my client. Such as furnace covers and electrical panel covers. I do not remove anything on a water heater.
I guess it’s up to Inspector preferences! :thinking:
If the water heater has a readily accessible door to observe the internal components, it is absolutely acceptable to access that door and make observations.
