system
(system)
Originally Posted By: jschwartz1
http://www.nachi.org/bbsystem/usrimages/D/DCP_3442.JPG ]
Image: http://www.nachi.org/bbsystem/usrimages/D/DCP_3443.JPG ]
Thanks,
Jay Schwartz
Coast To Coast Home Services, Inc
www.Coasttocoasthomeservices.com
Southeast Florida NACHI Chapter - VP www.floridanachi.org
NACHI - Legislative Committee Member
MAB - Member
system
(system)
2
Originally Posted By: bbadger
Yes a breaker in the panel can serve as the disconnect.
It has to be 'within' sight.
It would have to be a breaker with an ampacity that matches what the label on the unit requires.
If the label specifies only fuses you have a problem.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
system
(system)
3
Bob,
Thansk for the quick response. The unit is a Goodman. Any thoughts on the fuse or breaker. Model #CLJ36-1 Serial #0100451031
Thanks,
Jay Schwartz
MAB - Member
system
(system)
4
jschwartz1 wrote: |
Bob,
Thanks, |
Ah... sure, do you know where I left my keys?
No, I do not have any idea what that means.
When I wire a unit there are three things I look for on the tag.
1) Voltage
2) Minimum circuit ampacity
3) Maximum Overcurrent protection.
I do not look at model or serial numbers.
Maybe someone else has the info or you could try and get the info from the makers web site.
Bob Badger
Moderator at ECN
system
(system)
5
thanks. i will see what i can find out.
Jay Schwartz
MAB - Member
