Existing panel in the garage is 12 spaces /24 circuits 100 amp (no main disconnect breaker) ,( no empty space) and I need to add 1 new subpanel next to it , the new sub panel is a 100 amp 6spaces / 12 circuits . I want to make sure that I will wire the new subpanel correctly !
Looking for help ?
Hire a licensed electrician!
Tony’s got you covered safely.
This is not a DIY website or Forum.
Contact your local Building Dept. as they are very helpful and usually have handout pamphlets to assist you with your projects.
