Do you remove the dishwasher bottom cover?
There you go.
Not always easy to do depending on how it sits though, but a good idea.
Now that’s a good tip. If it’s wet I guess I’ll still take the cover off to get a picture, but still, I like it!
Thanks Jeff!
Most of the panels its easy to loosen the screws with out removing it all the way.
Jeff that is a great idea
By the way I do the same with toilets if I suspect a leak, and no caulk around the base.
Good tip Jeff.
I have to say I’m a bit disappointed to hear a CMI and others recommend you not turn on a diswasher.
www.MauiHomeInspections.com
From the nachi sop.
Plumbing:
E. Inspect the interior water supply including all fixtures and faucets.
F. Inspect the drain, waste and vent systems, including all fixtures.
