Block basement wall, leaks, Eastpointe MI
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing81
Am tryyyying to help some of you… and some homeowners, got MILK??
Just because YOU may NOT see any crack on the inside of a block basement wall does not ever mean, there isn’t 1++ EXTERIOR cracks or cracked parging etc.
- Saw-cut concrete needed to hand dig, waterproof corner.
Next few photos, digging duh biiitach out, clay soil, see exterior vertical crack??? Huh??? :-k #-o:mrgreen:
Photo of exterior step crack didn’t turn out.
Ummmmmmmmmmm, water/rain enters the hollow-block wall THROUGH these kinds of exterior cracks. It then falls through the lower blocks where it then, almost always, comes out onto basement floor, at the cove, at the very bottom of wall//floor.
Inside system companies most often tell most homeowners that, when they see this (water coming onto floor at bottom of wall/floor), that they have a SUPPOSED hydrostatic pressure problem UNDER the floor that only THEIR stOOOOOOpid interior system and sump pump can solve!!
Obviously, duuuuh, that is a stinky-butt, incompetent, negligent, lying BULLLSHT story!
12, 13 drain tiles looool. For those who incorrectly think the exterior tiles are the problem, your full O shtt! The drain tiles have ZERO to do with why there is 1++ exterior cracks in basement wall and why water enters through the dumb azz cracks, ABOVE the dumb azz drain tiles!!!
Looool, HHHHHHHHHELLooooooooo!
Photos 18–22 looking at the block wall from INSIDE duh basement.
Yes, you do see a step crack BUTT butt BUTT butt BUTTTTTT, you do not see any vertical crack on the side wall, near the CORNER!@!@!#@!!! If some cannot figure out what the hlll it is I’m explaining to ya then you better INCREASE the number of PILLZ yer popping, got that?
- Mr Fiore picking up the shtty az clay soil and GOD said, let it RAIN on BUBBA’s brrrrrain!
The city inspector was there, was ON SITE for…
:50 seconds!!!@!!@!@!@!@!@!@!!! loooooooooooooooooooooool
And some want to try and tell my azz or homeowners it is best to pull permit and have city inspect this??? HUH??? They didn’t ‘inspect’ sqqqquat!!!
Let it rain/E Clapton http://www.youtube.com/watch?v=y86kDFaJ2h4
