…but there ARE… exterior cracks and other exterior openings in the block basement walls that are the reasons why water gets INTO the hollow-block walls and is seen inside basements often, only at–along the ‘cold joint’, I-joint’, ‘cover’… YET interior system companies will try and bs homeowners and lie to them and tell them crap such as, ‘No, there are no cracks and you have a hydrostatic pressure problem under the basement floor, clogged drain tiles’ etc.
INSIDE a Grosse Pointe Woods basement, you do not, you will not see the vertical and horizontal cracks on the inside block walls… there are/were many EXTERIOR cracks and other openings in these basement walls
Outside, the area by the gas line…
See the exterior vertical crack? This is where, why… water enters into the hollow-block wall.
NO interior basement system repairs/waterproofs any of these cracks hence they cannot, do not, stop further water from entering into the blocks. Duh umm, gotta STOP water in order to stop/prevent mold, efflorescence.
Horizontal crack just above the footing ( not footer, footing, got dat?). You can also see some EFFLORESCENCE on the outside blocks, bricks and there is efflorescence on quite a few INSIDE blocks
In this area outside, pretty much the same type of exterior cracks… horizontal, vertical, corner cracks and a few deteriorated/open mortar joints…
Raising the grade, aka adding soil, against UNPROTECTED bricks and mortar joints can cause… can cause, can cause loool, some deterioration to some bricks and mortar joints and when they begin to deteriorate, like some here, water can/will begin to enter. SEAL the dang bricks and mortar joints if your going to add some top soil, ok? Got dat?
And this is the other side of the front porch, corner-vertical crack, horizontal, cracked parging etc… water can, does enter the blocks through cracked parging… uh huh
Back to the first hole dug, by gas line… sometimes the gas company or someone else doesn’t seal/put anything on/over the wall, the hole where the old line entered through the basement wall OR, sometimes they apply some cement etc but, NOT enough, too thin. Here, they applied plenty ‘around’ the hole but did not apply enough IN duh hole
If one goes back to the first video posted, inside the basement, again… lol, you will not see a HOLE in the wall where the old line came through the basement wall. You won’t see all the exterior cracks, its just the way block walls, parging etc… cracks and then allows water into the hollow-blocks, pretty often causes some amount of mold or efflorescence on parts on interior foundation wall. NO interior basement system nor sump pump nor Drylok paint repairs/waterproofs these exterior cracks and other exterior openings which ARE where the water FIRST enters into the blocks, yep.
This guy ‘gets-it’… basement waterproofing, unlike the many interior basement system scammers http://www.johnmcewen.ca/waterproof.php
Unbiased opinion, Fairfax county VA… scroll down to… Basement Wall DAMAGE… cause, RESOLUTION
http://www.fairfaxcounty.gov/dpwes/publications/marineclay.htm
You have NEVER and highly likely will never hear ANY of what has been posted here on Glen Haeges home improvement radio show or Gary Sullivans home improvement radio show etc… nope. They highly recommend INTERIOR basement system companies… same goes for the Better Dork me Business Bureau who has had at least several owners of interior basement system companies on the Board of Dorkectors for duh BBB… HMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
