It is in the garage . The house is on a * Foundation Details: Concrete Perimeter…
It is about 2 to 3 feet deep. dry … no drain… I have no idea what it is use for.
Sump crock that’s missing a sump pump?
Gravity/daylight drain
HDPE perforated drain pipe for sump/perimeter drain.
If it is meant to be a floor drain for the garage, you might want to check local codes for oil/water separator depending on discharge point.
the house was built in 1985
Never have seen that in a garage. Is the foundation slab-on-grade?
Slab on ground
As @mcyr said, it is likely a floor drain meant to drain water from the garage floor. Was the floor sloped slightly towards it?
I have one just like it in my garage, except I don’t have it tiled to the exterior. The water just soaks into the dirt at the bottom.
thank you everyone
Catch water basin, Several issues going on.
