Originally Posted By: rray This post was automatically imported from our archived forum.
I had my first inspection with dormers. Interesting to say the least. First picture shows the three dormers. There was no access to the interior of the dormers, either from the exterior or from the attic. Between the left and middle dormer in the attic was additional framing added to connect the trusses, shown in second and third pictures. These were very close to each other (if you look to the far left in the second picture, you can see the framing shown in the third picture, and at the far right of the third picture is the framing in the second picture). There was nothing similar between the right and middle dormers. Trusses were unevenly spaced. Homeowner said the dormers were built on the ground, raised into position, nailed into place, and windows installed. Comments?
Originally Posted By: rsummers This post was automatically imported from our archived forum.
I would be sure to check for eave vents. Its odd that the builder didn’t open them up to the attic. With out proper ventilation you could have a condensation issue with the windows.
Originally Posted By: dlabrake This post was automatically imported from our archived forum.
We sure do run into some funny things. This client was advised that a leak had occurred around the dormer but had been repaired. He did not know what the repairs were.
My report indicated:
"Poor roof design has a valley directly meeting the E side of the front facing dormer. This roof valley will channel large amounts of water into the side of the dormer. Flashing in this area must be perfectly installed to prevent water penetration. Normal 4" step flashing may not suffice, 6" step flashing may be required. Consult roofer for opinion."
Hopefully you can see from the picture the valley in question.
Poor roof design?
Consult roofer for opinion?
Perhaps you were too easy? How about "Sue builder/developer/architect for cost of house."?
