Double Tapped Main
Originally Posted By: tgardner
http://www.nachi.org/bbsystem/usrimages/I/IMG0096.JPG ]
Originally Posted By: kwilliams
Member - MAB
http://www.nachi.org/convention2006.htm
Originally Posted By: dvalley
Not to mention the neutrals mixed with grounds under the same lug.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: chorne
Hi Tim,
is that #12 a lightning supressor?
Carla
Carla’s got a good point.
I see lightning supressor's tapped there all the time.
David Valley
MAB Member
Originally Posted By: cbuell
I don’t like the idea of locating the surge protector there because of the difficult of future serviceing. And how about the copper/aluminum connection?
The instructions for a surge suppressor says it is supposed to be connected through a breaker.
It can be a branch circuit breaker, like the one to the dryer but it has to be on the load side of the service dissconect
Originally Posted By: whandley
I bump in to this weekly on older structures with smaller original service panel breaker capacities. Owner doesn’t have room to add a sub panel breaker, so they boot leg wiring direct to a smaller sub panel adjacent to the main. Call the electrician. icon_idea.gif
You can legally splice a service conductor but that is not by double tapping the main breaker and the conductor should be sized to the disconnect.
If someone used a legal splicing method, bonding bushings on the raceway and service rated equipment for the second panel it would be legal (also made up as a “main” AKA service disconnect).
You can have up to 6 of these. This is not the type of thing amateurs should be trying.
