Draft image: Kick-out Flashing
I second this ^^^^^^
Got it. I’ll start implementing this for the draft images going forward. Thanks for the feedback.
I will give it a third motion.
Zak, keep in mind that if these images are used in an inspection report, the likelihood that it will be viewed on a phone with a second image (or even sometimes a third, depending on the software) stacked side to side on the screen is very high. When making images with labels, shrink them down to 1/2 the width of your own phone screen and see how they read.
Interestingly during an inspection last week this detail came across my desk…
Which shows a self-adhering membrane.
Although the detail poorly describes the membrane installation.
I have seen a couple custom home builders do this very thing. They use the same Ice & Water Shield that is used as on the bottom row of roof underlayment on the wall. The idea being that it adds protection to the wall at the end of the gutter should the kick out flashing get damaged or the gutter cap leaks onto the siding.
Exactly we commonly call it “peel n stick” underlayment/flashing.
As stated above it typically would be installed at kickout flashing locations directly to the wall/roof sheathing area before any house wrap/siding or roofing details are applied.
