I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Your experience helps to make these improvements to add to make quality images. Thank you!
Looks good to me, Zac.
Lets see what others opinions are.
To tell you the truth I have not seen standard single ply roll roofing with granular minerals top coating 36" wide in stores for quite some time. I used this for sheds and know of a roofing contractor who got litigated for putting the product on a reasonably sized church roof deck that was not visible from the street to cut corners. It was his son that had the bright idea.
Off the cuff, starting with an absolute such as "All. Standard rolled…
I would consider removing the word all.
Terms such as Standard, Common, or Typical are better IMO
The fiberglass layer is the same as the asphalt or bitumen layer. The layer beneath it is unlabeled.
There should be no visible granules on the roll. The granule side touches the back side of the roll.
BTW, I just checked a roll I have in my barn and it does not have the 3” ungranulated lap edge. My roll has aggregate edge to edge.
