so its 3 degrees here and i went in my attic to check to see if my old windows were holding up ok and notice a puddle of water under my condensate pump hooked to my furnace. the line was frozen and no shut off wire was installed to stop it from pumping so water was leaking out of the seems basically.
last year i had a furnace installed in the basement and attic. my other furnaces were the old ones from 1980, so the new furnaces had to be hooked up a bit different. the old one never had a condensate pump.
they hooked a plastic flexible line upwards onto another pipe and zip tied it across the ceiling and then shoved that tube into previous old pvc pipe
the attic gets to cold for this and freezes the line then the pump overflows. on top of that the old pvc pipe they spliced into which is around 30 yrs old doesnt angle very much at all
the company refused to come out and look at their installation or anything at all. didnteven tell me what to do, to turn the furnace off etc.
so i had a new furnace guy here today. he basically said the way they ran the wire its prob just going to continually freeze even if we wrap the flexible plastic, the pvc leading outside is prob still going to freeze. i also have blown in insulation a few feet deep on the entire attic floor making this worse to get to anything at all
the only solution we came up with is using pvc pipe on the pump, trying to slope it as much as possible by moving insulation out of the way, wrap it in heat tape, and then put insulation over that. and then heres the big thing, running that pipe into the stink pipe by the wall.
will this be ok? its relaly the only solution that makes sense to keep it from freezing, and the closest place to drain it because the old pvc pipe goes under the corner of the house into the insulation and outside down the entire house in some sort of metal tube and its a victorian so it also goes through this custom ridge that sticks out ofthe house. in short itll be a nightmare to even get to that spot. the initial installers never wrapped anything and never said hey this might freeze on you etc. i dont have a problem with the ac water draining in the summer but were prob going to just run that pipe into the same stink pipe as well so if any of that 30 yr old pvc pipe cracks it wont rott my wall out for months before i notice it.
i dont even know if im on the right webpage asking this, sorry if im not, i saw a different thread where someone tried to do something similar. im just really lost right now. i have my pump temp draining into a bucket until the guy can comeback in a few days and re route this stuff
edit, updated with 2 pics and a video that i took before i had a furnace guy out. i drew a yellow line to follow drainage line to make it easier to know what your looking at.
edit, getting a 422 error from pics, had to remove them
