Drain vent question.
Originally Posted By: wdecker
Just a quick question of all you plumbing nerds out there. icon_surprised.gif
When draining a bathtub, what is the cause of excessive gurgling noises?
Inadiquate drain vent? Vent too far away?
Usually found when the bathtub drain is a fair distance away from the wall, like in a whirlpool enclosure.
Any ideas.
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
Originally Posted By: aleleika
vented is a gurgling or belching noise when the fixture drains"
If you suspect that a P-trap is not vented, mention it to the customer and record it in your report. Improperly installed vent pipes should be reported as a safety hazard.
A. Dan Leleika
www.a-teamhomeinspections.com
