Drainage over windows with hardcoat stucco
Hello,
I have a client who has a very large set of windows and I have concerns about how moisture will be able to exit if trapped behind the stucco over these windows. The property has the proper weep screeds at the bottom of the exterior walls but nothing over these large windows and nothing between the different floors. Just looking for some clarification and hopefully to be pointed in the right direction.
Thanks
You can start with these:
ASTM C926
Portland Cement Stucco Standards
No weep screed above openings woul[quote=“Tripp Walker, post:1, topic:231147, full:true, username:twalker12”]
Hello,
Thanks
[/quote]
d be a concern to me.
Thank you! This looks great.
Thank you. This really helps.
Image or images would be nice.
Flashing - Drip Cap
TechNote - Window and Door Flashing: Code Requirements and Best Practices
ASTM E 2112 – 07: Standard practice for installation of exterior windows, doors, and skylights.
I was called out for a consultation. (NO pics) I will be going back on the 28th and will take pics to share. Thank you for the info. It is really helpful.
Our pleasure Tripp, speaking for everyone here.
