In addition. The electric company service drop, service point, and service entrance conductors are too close to the window. They must be at least three feet from either side, and the bottom of the window if it is a window that can be opened. When located above, at the top of the window, the SEC’s are OK.The point of attachment is also missing.The electric utility company should be notified.
Good point about the 3’ clearance joe, I think it would be hard pressed for the POCO to update that however in the sale issue and to be honest with you I don’t know when the 3’ came into effect…as long as I can remember…good to note for the liability of the HI but in practicle terms I don’t see that being changed by POCO because of a HI report.
Alot will hinge ( no pun intended ) on if that window actually opens or not…but as you also might have guessed…I am sure it does open.
Thats new construction Joe…do you have any idea when the 3’ clearance from windows came into effect…I remember it being that way as long as I can remember…any idea?
[quote=pabernathy]
Good point about the 3’ clearance joe, I think it would be hard pressed for the POCO to update that however in the sale issue quote]
Actually, as home inspectors we don’t concern ourselves so.
We merely point out the fact. If the buyer/seller/anybody wants to take issue with PUCO (Public Utilities Commission of Ohio) that would be their’s to do.
If we don’t point it out, and something–anything–arises later, we haven’t covered ourselves very well.
