Originally Posted By: rcloyd This post was automatically imported from our archived forum.
Barron,
I cannot imagine any building code permitting an exhaust fan from a bathroom to vent into an attic. Perhaps the local building official allows it to happen out of ignorance. All dryers should be vented to the outside in accordance with the manufacturers installation instructions. The IRC requires all dryers ducts to terminate to the exterior of the building with the exception of condensing type dryers (intended to be used with no vent).
Originally Posted By: mcyr This post was automatically imported from our archived forum.
Hi. Baron;
No matter what State you are in, the dryer vent should go to the outside, and also is limited to a 15 foot run on most models. Their are exceptions and related alternatives to this, but I will not get to that.
Originally Posted By: jonofrey This post was automatically imported from our archived forum.
The IRC limits the length to 25’ maximum, with exceptions.
I called out a dryer vent on a pre-drywall inspection. It had 25' of straight vent and three elbows. The builder wanted me to send him the code page. So I did, today. Witht the three elbows, the length is the equivilent of 40'.
Same house had no upper roof ventilation. Builder said soffit vent was enough becuase it's engineered ya know. Cool, I don't have to send you the code reference on that one, you can just send me the engineered design!
My post indicated 15 feet maximum, had already included the exceptions.
A minimum of two 90 degree bends will almost always be required.
Five feet of duct is lost for every elbow. 25 feet minus 10 feet = 15 feet.
Most dryer Manufacturers will approve 15 feet of running duct.
If further than that, there exist in-line boosters that are readily available from different Manufacturers. These boosters will enable dryers to extend the venting to 25 to 30 feet, depending on the Model. An electrician needs to provide a micro switch to contact the booster when the dryer is activated.
Originally Posted By: bgentry This post was automatically imported from our archived forum.
I had one the other day that vented into the heating ducts. I bet it got pretty warm in the house (which didn’t have A/C) during the summer when doing laundry.
