Electric Dryer venting into garage
Originally Posted By: jmyers
Have a question.
I have an electric dryer venting to the interior of a garage. Is there any code requirement to vent the dryer to the exterior? Gas, yes but what about electric.
The dryer is causing lint build up in the electric panel which is also located in the garage space.
Joe Myers
A & N Inspections, Inc.
http://anii.biz
Originally Posted By: dbush
Joe, I had one like that a couple of months ago, but it didn’t cause any lint build up. 3 Car garage with some open windows. I actually couldn’t find anything saying it was wrong.
Dave
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: sbyrnes
Not sure about code, but I write it up as needing repair if it is venting into the garage without an indoor vent filter. It’s a fire hazard. Same as if it is venting into the attic.
All Corners Home Inspections, Inc
Serving Pasco, Hernando, N. Pinellas & N. Hillsborough counties
Originally Posted By: jhagarty
Violates Uniform Mechanical Code.
Does PA follow this code ?
http://doityourself.com/appliance/coderequiredryervent.htm
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
The excess moisture will also cause any texture and tape on the sheetrock to peel away over time.
The idiot that built my sister-in-law's home did the same thing. Would of took a 10 foot piece of pipe and a 90 to run it to the outside.
Now almost all the tape and texture have peeled off the ceiling and walls in the garage.
Don't know why she continues to leave it like that.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: dhadler
Also ran across this situation…wrote it up as a possible Hazard due to both fire and CO penetration into the home.
As most of you know those dryer flaps are usually always half open from lint build-up. This is as bad as the EXTRA heating ducts that are added to help warm the garage without actually installing a proper separate heating unit (the way it should be done)
As far as I'm concerned these are very dangerous situations. Try this little experiment...after the appliance and duct has cooled down, (that is the heat flow outward has ceased) put a source of smoke eg. incense stick or smoke bomb, in front of the opening in the garage and see where the draft takes it. If the garage is cooler than the home which is the norm, the draft will take it down to the furnace or other appliance every time ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif) ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif)
I'm no code expert, but I'm sure these situations have to be against code.
Very dangerous situations.
Darrell Hadler
Five Star Home Inspections
Medicine Hat, Alberta CANADA
IRC 309.1.1
Joe Myers
http://anii.biz
Originally Posted By: mboehmer
IRC indicates that dryer exhaust ducts shall terminate outside the building in accordance with the dryer manufacturer?s installation instructions.
I write them up as needing repair if they're vented to the attic or garage as it is a potential fire hazard.
Originally Posted By: mboyett
Mike Boehmer…Mike Boehmer…dang, that name rings a bell. It’ll come to me, just give me time. icon_rolleyes.gif
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
Originally Posted By: dnewby
My house and all my neighbors that I know have the dryer vented into the garage. The dryer duct vented into the garage is very common way down here in Mississippi. The hot humid weather is about 100% humidity everyday.
Originally Posted By: lewens
Donna
I’m not trying to be a smarta$$ but I am very curious. Do you recieve any grief or sarcastic remarks re your last name from any of the boards in the industry???
Larry Ewens
From the great white north eh???
Originally Posted By: ddivito
Code also states that there will be no duct openings in an attached garage.
I usually write it up as a safety upgrade to vent it to the outside. I also supply the reasoning that exhaust fumes will, under certain circumstances enter the living space, CO, breaking the firewall, etc.
Remember, we are not code officials.
Originally Posted By: wwarner
http://www.nachi.org/bbsystem/usrimages/P/P2240484.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P2240486.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P2240487.JPG ]
Bill
It's only Rock 'n Roll.... but I like it!
