Thanks guys! I had a hard time photographing what my eyes could see through the wiring. Maybe I should have tried a panoramic shot of the label. The catalog number definitely indicates a 150amp panel. I was curious about the bold print below the catalog number which reads as: EATON 50A. MAX.
(the wordS “EATON” & “max” are mostly covered by neutral conductors in the picture)
Yes, it is MLO. Thanks for the clarification. I have since clarified myself about the cover & did not call it out in the report.
What is your take on the “50amp max” print below the catalog number? (Sorry the picture is obscured)
There is no doubt that the panel is 150amp (according to the catalog number) & correct for this application. I will try to find a clearer picture of a similar label.
Yeah, there wasn’t any good angles to get a clear picture. Thank you for your help nonetheless!
I will post up a picture when/if I come across it again.
Previously questioned is a CH 150 amp panel
In the middle (behind the neutrals) it says
EATON 50A. MAX.
You can see the “N” in EATON, 50A., then the “X” at the end of MAX.
Yet here is the catalog number showing it is a 150 amp panel.
I would almost assume a typo but damn, that would be a big mistake. I have several factory engineer contacts at Eaton. I will send you pictures to them for review and comment.
