I would write this up as a firewall problem. The dryer vent runs through the firewall separating the house and attached garage.
Do you concur?
Comments appreciated
Do you concur?
Absolutely. Not to mention it will be messy.
Thanks Joe -
Messy yes, and the moisture air would not be good either.
Darin how old is the house? I run into this a lot in my area, they are normally 30+ years old
House built in 1966.
It doesn’t matter how old it is, dryer vents must terminate to the exterior of the structure - including the garage.
When done properly, this will be continued with a (min 26 gauge) steel vent to the exterior. At that point, it will no longer be a firewall breach.
Thanks Jeff.
