Originally Posted By: bkelly1
http://www.nachi.org/bbsystem/usrimages/H/HPIM1972.JPG ]
“Do, or do not. There is no ‘try’.” -Yoda (The empire Strikes Back)
Originally Posted By: Jay Moge
Originally Posted By: pdickerson
Originally Posted By: bbadger
pdickerson wrote: |
Exposed splice - should be in j-box. |
pdickerson wrote: |
Improper staple - should be approved for the purpose (no bent nails). |
Quote: |
334.30 Securing and Supporting.
Nonmetallic-sheathed cable shall be secured by staples, cable ties, straps, hangers, or similar fittings designed and installed so as not to damage the cable........ |
Quote: |
Approved. Acceptable to the authority having jurisdiction. |
pdickerson wrote: |
Exposed NM-B wiring - should be in conduit where subject to damage. |
Quote: |
334.15 Exposed Work.
In exposed work, except as provided in 300.11(A), the cable shall be installed as specified in 334.15(A) through (C). (A) To Follow Surface. The cable shall closely follow the surface of the building finish or of running boards. |
Quote: |
334.15 (B) Protection from Physical Damage. The cable shall be protected from physical damage where necessary by conduit..... |
pdickerson wrote: |
White wire not re-identified. |
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Originally Posted By: lkage
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
bwiley wrote: |
Ain't it great to have Bob back with his knowledge and common sense approach!!
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
