Hello,
This is my first post on the Canadian Forum, I am just up and running , based in Vancouver BC. Hoping to tap into your collective experience.
Are any of you guys out there doing end of warranty Inspections?
If so may I ask a few questions,
What is the usual period of Warranty?
How do you find what sub-divisions are nearing end of warranty?
Would you charge the same as a normal Inspection, I am assuming a newer home may take less time?
Is it an area that generates much Interest?
I look forward to some pointers, thanks in advance
There may be certain provisions an inspection must comply/meet before they can enter on the property or be given permission to conduct the initial 'pre-delivery" inspection. Certainly once the home is rightfully owned and titled the owner provides that point of contact for conducting the inspection.
Yes builders are required in Ontario to Register with the Ontario New Home Warranty Program aka Tarion. However if you build your own home and occupy it then it is outside the Tarion program. So it is possible to buy a new home from the builder/owner and not be part of the Tarion warranty program.
