Are any of you performing energy analysis as a service? If so, how many are/have you performed this year and what are you charging for that service?
I was going to add it as an ancillary service or stand alone inspection. The pricing is the sticking point, as for a ASHRAE level 1 audit the scale is $.08 - $.24 per square foot.
Would love to get some feedback from those of you that have provided this service. I am very familiar with this scope of work bc this was the bulk of my work at the local utility. I have and still could teach this subject. Im just not convinced on the pricing. Partly due to the fact we provided this service free at the utility tobour members.
No matter how much energy I use (electricity) my utility always says I’m not quite as good as my “energy efficient” neighbors but better than my neighborhood “average.” This is marketing hype that should entice me to want to do better, but I don’t buy it. I bet everybody in the neighborhood gets the same report! Fact is energy suppliers have trouble keeping up with demand so they’d like everyone to reduce consumption. It’s only going to get worse!
Thats funny that they send out reports like that.
When i was at the utility i would go to the members house, inspect, and give an indebth report on what was found. We were not allowed (by law) to discuss neighbors usage nor would anyway bc it is completely irrelevant.
We didn’t have an issue with keeping up and also maintained low rates and fuel cost adjustments (sometimes a credit). In the end my job was tied to demand management while also serving the membership via useful information to reduce their usage. Not all usage is good usage in the utility world and alot has to do with how well the co-op can forecast (we did this well).
My question was more geared to inspectors who offer this type of service to their customers. How often do people purchase this service and what are you charging?
I get the same crapola from Xcel Energy here. It always includes some speel about installing a “smart meter” so they can shut my electric down when THEY deem it necessary. Screw that!!!
Lol!
Most meters now are smart meters. Long b4 the smart meter, they have had the capability of disconnecting service remotely for well over 15 years now. That was my first job at the utility. Smart meters and smart systems are good and bad. I don’t worry about them disconnecting just because they want to. The demand management programs are something you have to opt into.
And if they ever (any utility) had to cut off large areas it would be done via substations or various feeders.
I just started doing energy audits and energy use modeling in conjunction with residential incentives from the Inflation Reduction Act (IRA). I recertified with Building Performance Institute (BPI) last month and have done 5 over the last month. Prior to the IRA it was maybe 5 per year, doing it with an expired BPI certificate. I let that certificate expire about 3 years ago due to reduced demand. Funding was cut about 5 years ago. Before that, when there was funding for the audit, I would do about 20 per year, mostly in winter. I’m in far northern MN, a sparsely populated area. I’ll see how the future goes. Funding is an important component to incentivize homeowners.
I charge $650 plus mileage. It’s a complete Building Performance Institute audit, per IRA requirement. Blower door, IR, CAZ test, fuel leaks, CO in furnace, water heater, oven, etc… Plus modeled improvements, savings/investment ratio. It’s about 6 hours on site, plus a day to do the report and modeling. Before it was all manual/spread sheets, but now I use a software program. Interesting, I get “green” folks motivated by carbon footprint, and equally folks who simply want to cut their energy costs. Clients get a $150 rebate or credit through the IRA towards the energy audit.
This work is totally independent of home inspections. I do get some radon testing out of this, a nice add on. Since this work is not home inspection and not governed by NACHI SOP or ethics clause, one can also attach this work to energy reduction contracting work if you like. I stick to just the audits. A younger person could make a viable business model out of this. It’s interesting work, not the scope of a home inspection, but very much an in depth analysis of home safety and home energy use issues, along with solutions.
A smart meter is totally different from a meter that can be shut off. The first is for folks who have photo voltaic or wind power generation. The meter goes backwards!
The meter that can be shut off is there to manage demand on the grid; off peak power. It’s used to power off peak heating systems and off peak hot water. Surprised you don’t see those two meter systems when you do home inspecting. We have a lot of those systems up here, many using Steffes storage room heaters or storage central heating systems. Very economical to heat and an excellent choice for tightly built homes.
Interesting fact: I recently became aware of a homeowner who is installing an air source heat pump in Duluth, MN. System will cost him around $2100 after credits and rebates, with a 5 to 7 year payback. On the same note, I have a ground source heat pump in my personal home that paid for itself in 8 years. I calculated the elimination of a propane bill against the increased electricity use to the cost of the system.
This is great. All of that is exactly what I did. I have been BPI certified since 2011 or 12, my renewal is this spring. I would forgo the blowerdoor as that is more than the level 1 audit, but have done my share of them and duct blaster tests. What software do you currently use??
If this type of service was to take off I would consider getting another blowerdoor and software to do a test in/test out blowerdoor test.
Same in my area. Almost everyone is on some type of off peak program. It’s a no-brainer when you dig into it.
I have my water heater, AC, garage heater, furnace, and two basement baseboard heaters on the program. I rarely ever realize when they are controlling my systems. About the only indicator is if I notice exhaust out of my furnace vent. Saves a boat load of money over alternative energy sources (at least in my rural location).
I offer an energy loss analysis as an add on for a home inspection. It’s pretty basic. I read about the energy analysis reporting and it was more in depth than I was interested in investing in. I wasn’t interested in analyzing energy star ratings, 12 month energy bill analysis, blower door testing, etc. When doing my normal home inspections I saw a need to create a new category for energy loss in the home & point out improvements that can be made to save on energy bills. I recommend the “common sense” energy saving stuff I see every day such as uninsulated duct work, old less efficient furnaces, insulation (R Value, missing or air gaps), air leakage at windows & doors, open fireplace dampers, etc. I use my thermal imaging camera for my photo proof. The client can see exactly where energy is being wasted or lost. My goal is to offer reasonable practical and affordable advice to a new homeowner getting an inspection. I’m not looking to tell the homeowner they have to replace every window, door, and reinsulate the home. I only charge $100 to add this service on to my home inspection report. Clients really appreciate the energy loss section. It’s not technically exhaustive by any means, but it’s good simple advise.
Exactly!
That in large is what I offered while at the utility and was thinking of offering as an add on service. I was thinking $100 min depending on the size of the structure.
