Equipment purchase
I am just now getting started in the home inspection business and am purchasing necessary equipment. I am considering purchasing a product by tpi, it is a combonation CO and combustible gas leak detector. It seems to make sense to buy one instrument instead of two for economic reasons and I would only need one replacement tip instead of two, but I know nothing about this product. If you have heard of this product could you advise me as to it’s performance and reliability
Is this the one you’re looking at? http://www.professionalequipment.com/tpi-combustible-gas-leak-detector-720b/combustion-analyzer/
First downside that I see is the CO detection is not quantifiable, meaning it will tell you if there is a leak, but will not give you a reading at to the extent of the leak. This is necessary, as there is virtually always some CO “spillage” from fossil fuel burning appliances.
Yes, there is a reason why most of us that use CO meters use dedicated meters.
PE is a great site for quality tools, with many choices. Their customer support is great also, so just give them a call and discuss with them. Good luck.
I use a dedicated CO detector for the reasons Jeffery explained.
This is the one I use. Works great.
http://www.indsci.com/t40/
Thanks will do
I’m with Jeff on this too, Here is what my team uses.
I use a combination CO combustible gas meter by TPI (link below) Gives you ppm CO and has a tick for combustible gas with a level indicator. I have used it for 3 years. Only issue was a bad combustible gas sensor that they replaced for free. Has worked well. To date has found 3 major CO leaks in homes while checking.
http://www.tequipment.net/TPI775.asp?Source=Google&gclid=CLiR8ejStLUCFYpDMgod5hEA4w
For the type of CO detectors that actually give you parts per million readings, what level is considered unsafe?
Anyone using one of these? Any feedback?
http://www.extech.com/instruments/resources/datasheets/Co10.pdf
http://www.amazon.com/gp/product/B004HWT6DY/ref=s9_psimh_gw_p60_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1MKXZR3KBWNGK7SJTEMJ&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
I forget where I read this and my meter is alarmed at these intervals. 35 parts will make it dangerous and start giving you headaches and other symtoms. At 70 parts it kills you. I tend to beleive that any exposure is bad over time. Lets say you get a reading of 20 parts per million. Do you call it up? I do because over time that 20 parts is going to be ingested and can have prolonged issues.
