Originally Posted By: dstoinski This post was automatically imported from our archived forum.
Does anyone have any good tips on removing aluminum siding? I have to remove several pieces to blow insulation in the walls of a two story house and of course the old siding has to be reinstalled.
Originally Posted By: lkage This post was automatically imported from our archived forum.
I’ve used a zip tool made for vinyl siding before with some success. It depended on the thickness of the aluminum how well it worked and doing it on a hot day helped because the metal was expanded.
-- "I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Originally Posted By: lewens This post was automatically imported from our archived forum.
Best tip I can give you is don’t do the removal on a very windy day. If the wind takes a piece and puts a kink in it it’s replacement time. The zip tool works great once you get the hang of it. This may sound obvious but put the pieces you take off where nobody is going to step on it. And yes I speak from experience with regard to the last tip. The kids came around, started roughhousing…you can guess the rest.
