but the question said “vynal”. that doesn’t have to be grounded, so the “best” answer in my opinion would have to apply to both metal AND vynal. i said C. if you ask me, i’m right. but than again, besides all my faults i’m perfect.
Originally Posted By: away This post was automatically imported from our archived forum.
Jeez, I hate questions like this.
I have typed three separate replies but then go back and re-read the question and replies and keep changing my mind.
Now I am back to thinking A is the correct answer.
B, C, and E are problems. D is not a problem since nails shouldn't be tight.
So by the process of elimination A would have to be the answer, but one could then argue that the problems need to be common to both metal and vinyl (like Jay) which then could eliminate A.
But on the other hand "metal" is a qualifier in A, which then precludes it being applied to vinyl. Which then meets the "except" qualifier in the question, or not, well maybe.
Originally Posted By: jjackson This post was automatically imported from our archived forum.
It is a confusing question because the word except is in there. It is asking what is not a problem on this list. Nails not driven tight is not a problem. That’s my story and I’m sticking to it.
Jeff,
We both got to the same destination but I have to admit I wasted a lot of gas to get there.
I am going to have to keep that "short cut" in mind the next time I test.
Originally Posted By: Aron Jacobs This post was automatically imported from our archived forum.
The siding is not required to be bonded by the NEC.
250.4 (4) Bonding of Electrically Conductive Materials and Other Equipment. Electrically conductive materials that are likely to become energized shall be connected together and to the electrical supply source in a manner that establishes an effective ground-fault current path.
-- Aron Jacobs
Electrical Contractor
Electrical Instructor
North Carolina
