Exterior Stucco
Originally Posted By: mcameron
http://www.nachi.org/bbsystem/usrimages/more/100_0587.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/100_0589.JPG ]
Originally Posted By: jpeck
Mike,
The stucco cracks are likely because the wire lath was probably improperly installed.
The rusting spots are ... likely because the wrong fasteners were used for the wire lath ... adding to the improper installation of the wire lath.
If this is a new house, and more houses are being built in the same subdivision, try to find one with the wire lath being installed, then look it over closely. IF by the same builder, may be the same sub contractor, and the installation are likely to be similar.
Jerry Peck
South Florida
Originally Posted By: CarlBrown
The crack! Is it a one coat stucco application? The stain! It could be a sliver of metal from the mixer . Or something that was in the sand. To see more pictures of bad installation of lath/windows/house wraps. Go to www.badstucco.com
If it was your house wouldn’t you want the best!!
Originally Posted By: dbroad
It cracks. There are three guarantee,s with plaster: It will get hard< It will crack> No one will steal it, for you have to break it to take it.
As for the stain, its probable a scaffold tie that was cut and not pushed in.
