Does anyone have any experience with an EZ Breathe venting system? pros or cons?. Effect on conditioned air loss? Their website is www.ezbreathe.com
Yup, they make me thousands $$$$!
In TN they cause more problems than the “perceived” reason they were installed for.
We tear out 100% of the ones we find because they are the cause of the real problems in a building.
You can’t remove Moisture, Radon etc. just by sucking it out of the building. For every CFM you remove, it must be replaced. This usually comes from places you do not want it to come from / through.
When you suck out humid basement air, the air your replacing it with here in TN has more water vapor than what was in the basement. Basement air is cooler and can not contain as much moisture (you can’t remove moisture with air that has more moisture). When you suck this air through the building envelope and it meets Mr. A/C it makes Rot and Mushrooms…
I have Thermal Images of this happening in Real Time. Not just a fluid dynamic theory.
Hey David,
Interesting. I get what your are saying 100% but can you elaborate what type of equipment they install and how it functions?
Does it connect directly to the HVAC return plenum? Does it pull outdoor air in through a pipe or duct with a filter?
Thanks man, appreciate the info in advance.
I haven’t seen them installed here yet.
Sounds like it would increase likelihood of ground sourced radon too.
Does not look like much more than a fan that sucks air out of the house .I am assuming you need entrance plus exit .Reminds me of a whole house fan in principle from what the pictures show .
The way the graphic look you are creating negative pressure and also pulling heat out of the home so must increase energy use as well. Still not sure how it is different from any exhaust fan ?
There is a fan indoors. A square dryer vent type exhaust to the exterior.
One way air flow.
I have seen HRVs used to do the same thing in a basement, difference being an HRV also supplies make up air and exchanges heat between incoming and outgoing air (so an HRV could also cool incoming hot air), and will collect any condensation that forms inside the unit and send it to a drain. Probably costs about the same too, I can’t find any ez breathe pricing information without giving them my email, and that’s not going to happen :-).
Seems you could put a window fan there and do the same thing.
My take on the EZbreathe
Report verbiage
An EZ Breathe system was noted, the system most likely will depressurize the basement area, with the potential of back drafting from water tank and furnace. The system can draw the conditioned air out of the basement and exhaust it outside. Expenses are paid to condition the air, now the air is blowing to the outside. Also the system can cause moisture laden exterior air to be drawn into the home.
The inside water control companies are selling these along with the interior water systems.
Every weekend all across the country Gary Sullivan is advertising and claiming he has one in his home, he also advertises other inferior systems like the gutter brush. http://55krc.iheart.com/onair/gary-sullivan-18272/
This guy pisses me off every time I listen. EZ breathe is on the home page slightly down on the right. He is making me sick!!
I haven’t looked at the actual fan but it sounds like it would definitely increase the potential for exposure to radon as well.
