False ground wire
Here is a graphic for a house inspection I had today. I know I have it labeled as After 1963 and Before 1963, but that date is a moving target so you can clarify that in any verbiage you attach to the graphic.
Thanks, Randy! Very helpful.
Just a suggestion Randy. Could you make the background of these electrical diagrams be maybe grey or a light blue? Everything white in color blends into the background.
Fussy ass, :smiley:
walt
Who? Me?
Nice graphic Randy, and to think all these years I’ve been calling it a bootleg ground. :grinning:
Here is one with a gray background.
Thanks Randy. Now I can see the neutral wires being a Mr. Magoo :+1: :wink:
SureTest 61-164 False Ground image.
Robert, one must be very careful with relying on the tester to determine if there is a false ground. If the outlet is not far enough from the electrical panel, it will show a false ground.
I’m not sure it needs any date, AKA 1963.
Actually it kind of makes it look like it was permitted until 1963.
Like this one.
I never heard that. Any reference material?
Situated 2 floors above the panel.
I know.
Do you understand how your tester determines if it’s a false ground? did you read the manual :slight_smile:
Obviously not!
Duh!
Why 1963? What happened then?
Was a false ground ever code?
Branch circuits did not require grounding until 1962. So when people replaced a 2-prong receptacle with a 3-prong, they needed a way to give it a ground and thus a false ground if a true EGC was not available.
You should have just said they needed a way to give it a False ground. Because that’s all it is. They did not give it any type of true ground.
I realize if the SureTest is within 15-20 feet of the main panel, the unit will indicate a false ground condition on a properly wired circuit due to its proximity to the proper ground-neutral bond in the main panel. If necessary, simply use a 3 conductor extension cord that is 20 feet long to make the
measurements.
I pack extension cables in my roll carry bag. I do not use the 24" inch cable that comes with the SureTest analyser. I use a 10’ foot cable. Makes prolonged bending over a thing of the past.
The picture is implying that it was once code to create false grounds. Was that true for a time? I’m fully aware of the switch from 2 to 3 wire circuits.
