I run across this issue a few times and wanted to pass it on to others. Typically in a basement wall that is shoved inward a stress crack will develop that is wider at the top than the bottom. At first glance it may appear to be the typical settlement crack which also is usually wider at the top than the bottom. However if you run a string line along the the top of the wall you you can usually detect the bow in the wall. Also if the outside of the foundation is visible the crack will appear more as a shrinkage crack uniform in width. Depending upon the geometry of the foundation and the volume of clutter in the basement you may not be able to determine if the crack was due to settlement or bowing. In this case more information will be needed.
Homeowner was told by INSIDE System terds that her house was settling and she needed piers or underpinning and an inside system done,pfttt!
There is NO settling,no cracked or dropped footing…no need to spend a shttload on anything other than exterior waterproofing.
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing29
Here, a diiferent KIND of INSIDE knothead!!!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofingIBeamsEtc#5443027730274186114
See what they applied on BOTTOM 3 blocks,lolol! ‘Waterproofed’? Hlll no!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofingIBeamsEtc#5443027684964339746
Says, LIFETIME GUARANTEE! lolololololololol!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofingIBeamsEtc#5443027656039531682
WHY did homeowner call my old dumb azz? Cuz their still leaking!@#$#@!! lol
WHERE o where is that LIFETIME Guarantee?
A total WASTE of money due to incompetent INSIDE BUTT-heads,period end of story!
The Rain,The Park and other things like…inside system terds
Came across that Randy. That is exactly what it does.
This one was patched, bowed about 1+ inch and minor crack at the bottom showing some leakage.
Basement?
Hi Randy,
You’ve done a great service with illustrations and covering some of this “ground”. Would you consider posting some common issues and illustrations with Basement and Slab on grade stuff…?
IMO, there is a considerable amount of information for inspectors, but some information to help identify some common structural issues would go along way for those to understand what to look for, if nothing else.
Albeit, a geometry lesson as well.
Additional structural references would be helpful to a lot of folks, for sure.
Battered basement foundation wall Russel. Bowed, old, and prolly has old potatoe digger lags for reiforcment. :mrgreen:
