Just had a previous customer call and say they had a plumber out for a slow drain and the plumber told them that the fernco type coupling is illegal and their inspector should have told them about it. Any thoughts on how to respond professionally?
Do you know if it’s allowed in your jurisdiction?
If this is new news to you, call your client and their realtor and tell them exactly that. If they are happy with the rest of your inspection, this may not be an issue to them, especially if it isn’t leaking. Sounds like the plumber is trying to throw you under the bus. It happens in various ways now and then.
In all honesty, until seeing your post, I was unaware that they are not allowed inside a building by UPC. I see them regularly inside homes where I inspect.
If I was in your position and the client was insistent, I’d offer to have a plumber replace the coupler on my $$$. For me, I’d offer to do the work myself, since a plumber is not required in my jurisdiction. You need to use a coupler that does not have an internal shoulder, so you can slide it up the pipe before you glue it.
Fernco is a well-known name brand. In terms of what is or was permissible per code, it depends and can vary. What state/city was this home located in? What type of material is the sanitary sewer pipe? Was the Fernco rubber coupling installed above ground or below ground?
Mechanical joint couplings for reference:
2024 International Residential Code (IRC) - P3003.4.3 Mechanical joint coupling.
Generally, if a mechanical joint rubber type coupling is installed above ground AHJ code inspectors want to see the rubber coupling shielded/sleeved. But, not everywhere is everything the same.
Was the drain slow when you inspected? What condition changed? Why did the customer contact you? What do they want?
We don’t inspect to code. If the drain performed at the time of inspection and the Fernco coupling did not leak I would not be concerned.
FYI
IPC 2021 & Ohio 2024 code
707.1 Prohibited Joints
The following types of joints and connections shall be prohibited:
- Cement or concrete joints.
- Mastic or hot-pour bituminous joints.
- Joints made with fittings not approved for the specific installation.
- Joints between different diameter pipes made with elastomeric rolling O-rings.
- Solvent-cement joints between different types of plastic pipe except where provided for in Section 705.16.4.
- Saddle-type fittings.
You’ll hear that periodically, no matter the item or component, “the inspector should have told you” is a common battle cry from whatever vendor or tradesperson shows up.
“You must be mistaken as to which Inspector you are referring to. The Building Department Inspector (AHJ) that performed your Permit Final Inspection is whom you mean.”
OR…
“What did the City Inspector state when you had the Permit Final Inspection performed? Seems like maybe I should make a call for their input on the matter!”
It depends, do you want to take responsibility for an “illegally” installed component that you didn’t report? Go back to your Ohio SOP:
“A licensee is not required to determine or offer an opinion about…the compliance of a system or parts of a system in a property with past, present, or future requirements which include but are not limited to codes, regulations, laws, ordinances…”
Our industry is our own worst enemy on all this code and jurisdiction crap. A lot of us (usually new inspectors but not always) run around citing codes then want to hide behind the, “we don’t do codes” thing. Too many jurisdictions, too many code changes, too many different years of houses we inspect. Everyone give it a rest with the codes and home inspections. I’m not aiming my comments directly at anyone but if you’re posting numbers with decimals you’d be at the top of my list if I were.
If this coupling was used above ground, your plumber is correct. The home inspector should take responsibility. I call these couplings out every time I see them. It has nothing to do with code. Just like inspectors call out polybutylene, they think their responsibility and knowledge ends there.
So obviously just a contractor trying to throw me under the bus. I explained to the customer we are not code inspectors and the drain worked fine at the time of inspection. It’s also been 5 months since the inspection. I asked the customer what they expected from me and they just said “I don’t know, the plumber just said to tell you this was illegal and you should call it out” Do any of you regularly call these out.
That’s exactly what I would have told a client in this instance as well.
I never have and never will unless it’s leaking, corroded or has some other visible defect.
On the other hand, if I see a drain pipe that’s taped up, I do call those “fixes” out as improper repairs.
There are several legally obtainable DIY/handyman plumbing components on the market that do not meet code: Fernco’s, accordion drains, saddle taps and valves, S-trap kits. All of which will make my report as non-standard.
But, whether these are legal, illegal, code compliant or not code compliant is irrelevant. It also doesn’t matter if one plumber agrees with another plumber about the legality.
What matters is if the component was in failure at the time of the inspection and if you want to take responsibility for something that you are not legally (and hopefully contractually) required have an opinion on.
What is the customer wanting?
Were they actually told that the inspector should have caught this? Or was it a case of the plumber saying that the Fernco is not up to code and wanting to be paid to correct it? In turn, the customer needs to find someone to be mad at.
Where I’m located, the purchase agreements state that negotiations cannot be made based off of code violations. So, items like electrical issues that do not meet today’s codes are turned into safety hazards. Does a Fernco meet this threshold? Is the customer going to say, I would not have purchased the home if I knew it had a Fernco?
Is this also a case where the plumber would make a big deal over a Fernco, but criticize an inspector for calling out an S-trap?
In the OP’s initial post a previous client calls and informs they had a service call by a plumber for a slow drain. The plumber at some point mentions about an ‘‘illegal ‘‘ fernco rubber coupling.
Something doesn’t add up. Were the 2 mutually exclusive? Maybe there was a slow drain at the rubber coupling because one side of the drain pipe was elevated causing a lip or ledge for debris to get snagged on, yeah? It’s helpful to post pertinent information if looking for more technical advice or thoughts. It’s also helpful answering others legitimate questions. There are hundreds of variables here.
But if the situation was simply a state/sop home inspection was performed, then a previous client calls 5 months later to say ‘‘ hey I just wanted to let you know that we had a plumber come out to fix a slow drain. The plumber said the slow drain was caused from an illegal rubber coupling. ‘‘
I would probably just say something similar to ‘Per the signed agreement and a standard home inspection we do not inspect for code compliance, or any system/component underground, or any system/component that is concealed. Unfortunately, all homes with have maintenance and issues that arise in the future. But thank you for that information. I’m pleased that you were able to get the issue resolved. Is there anything else I can assist with? No? Great! Have a wonderful day’.
The OP asks in a follow-up if any of you call these out. For me, I do consider an above ground rubber coupling that is not sleeved a concern (most of the time) for a few reasons. One concern, they are often installed in crawlspaces, basements, attics, etc. and prone to vermin chewing on them. Another concern is the material degrades overtime. The rubber loses rigidness overtime. Then those two pieces of pipe that were cut become offset. It’s more of a concern for me at larger and/or horizontal piping vs. vertical. But, I do make some exceptions and it is subjective
. For example, if I see one small 1.5 or 2 inch rubber coupling in good shape on a 30 year old home, it will not make it into my report.
In terms of knowing building codes and standards, I find referencing them for information to be very beneficial. But, in over 20 years I’ve never once sited specific building codes or lack of compliance to a building code in my report. Like this situation here, having knowledge of building codes and understanding the application and implication of said building codes can be helpful!
