Fire wall
Originally Posted By: tallen
Is this a breach of the fire wall?
The garage ceiling is not firerated as it has been modified by the homeowner.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: rpalac
It’s not a breach of the fire wall, it simply is not fie rated…period.
Is it a garage?
Was it built after the 30 min requirement.
What are the local codes for the type of use it is beeing used for?
the pic is of the garage side wall. Home built in 1983.
It’s ok I found it. Since the ceiling has been modified it apparently does not matter what’s going on above it. Is this correct?
Originally Posted By: jpope
tallen wrote:
Since the ceiling has been modified it apparently does not matter what's going on above it. Is this correct?
Huh?
If there is a living space on the other side of that wall (ceiling - whatever), it is required to be rated material.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Well, part of the ceiling in the garage is fire rated, but Harry took the wallboard down to do some wiring ,and replaced it with 3/8" plywood with 1/4" gaps between sheets. As you can see in the pic there is also a nice hole between the garage attic space and the living space. Does that make more sence? icon_confused.gif
Yes, It wrong
Thanks.
Originally Posted By: rbracklow
Tod,
Jeff is absolutely correct. Typically the fire rated wall is always between the Garage and living area in the attic. This area has to be fire rated and where there are any penetrations, such as electrical wires, etc. they have to be routed through conduit and properly sealed using fire rated adhesive.
Ron.
The highest compliment my clients can give me, is the referral of their Friends, Family and Business Associates!
NorCal NACHI Chapter Founder and Chairman.
Thanks all. icon_biggrin.gif Heck the hatch was plywood . I believe that in itself kinda blows the fire rating.
