firewall
Originally Posted By: Rafael
hello
can someone tell me what there thoughts are on a firewll. this pic
is a garage 1975 that had no ceiling untill the owner partialy installed one
on the firewll side. i cant see if there was a wall that is attached between the liv space and garage on the top part of the garage because of the partial ceiling added , but if there was a wall on the otherside and the new ceilng they added had holes in it , would this become a safety issue.
how would you write this up witha garage witha partial ceiling…
thanks
[ Image: http://www.nachi.org/bbsystem/usrimages/f/firewall.jpg ]
Originally Posted By: lkage
Firewall between garage and house is not visible.
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
Originally Posted By: mcyr
Rafael;
The picture dose not do justice.
Most homes with an attached garage with no ceiling or a ceiling, should have a barrier in the attic for separation.
Although, this is thought of as a fire wall, it is actually a fire barrier, and smoke barrier.
If in your case you could not access the area to verify this, that should be noted in your report as unaccessible.
Marcel
thanks , you been very helpful
Originally Posted By: aleleika
Picture of firewall is not visible ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
A. Dan Leleika
www.a-teamhomeinspections.com
Originally Posted By: Steven Brewster
Does anyone know what year that ceilings and walls for attached garages and garages beneath homes were required to be fire rated?? I see a lot of older homes that do not have the drywall and have either 1/4" plywood (paneling) or OSB.
Originally Posted By: Jay Moge
not real sure on the year, but i’ll bet it’s before o.s.b. was around. icon_cool.gif
Check your local AHJ
thanks Kevin. your answers are so much better than my smart a$$ ones. icon_cool.gif
Originally Posted By: bkelly2
http://www.codecheck.com/pg09_10building.html#fireprotection
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
